Baffled
mr 88
Have a 2006 " 4 stroke 90hp " Johnson " ( made by Suzuki ) , just bought it . Check the oil after it sat for a week . Read the stick and it shows a little over a quart too much . Drain the quart ,check the stick, spot on . Take the maiden voyage yesterday, get back home , check the level a day later . Now it reads about a quart low . Tilted the engine up and moved it ,left-right so any pockets of oil would drain into the pan . Makes no sense to me , especially after reading it was a quart over . Reciept for oil change was in the paperwork ,showing the correct amount of oil they put in before it was sold to me . Any thoughts?
mr 88
My question is , ( why was the stick showing a quart over to begin with after recent oil.change , remove quart , dipstick.spot on . Run it , then reads a quart low ) what is causing the discrepancy , errounios readings ?
tphoyt
Was it laying down durning transport?
If so maybe things didn’t have time to settle before you checked it?
mr 88
No ,been hanging on the same transom for years . Oil readings have been about a week.apart ,boat is sitting on a level driveway .
Perhaps trim level us different.----Use a carpenter square to read with same condition each time.
mr 88
Sitting exactly where it was the week before as I have stops for the trailer on my driveway that were not moved . Even if it was off a bit , the readings would be fairly close , not a " mile " apart , which is a one quart with the capacity at 6 .
airshot
I do not own a four stroke outboard, but have heard from others that getting consistent oil level readings is a problem with four stroke outboards, so it seems your not alone with this issue.
saltchuckmatt
Gravity is off from global warming mostly caused by all the electric motors now.
Really, though. If it's that much of a concern, drain, put in the right amount and study it again. Be happy it's not back to a quart over and full of water.
