Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
hestons - I would be careful of any home remadies. Most of the suggestions involve a lot of scraping and use of acid (for fiberglass). I would contact the manufacturer. If you don't know who that is, contact Zodiac and tell them of your problem. Others may have some good ideas but I would be concerned about what they would do to the fabric and seams.
Pressure washer and Bottom cleaner. Some acids might be very toxic so please watch out. Becuase if your not, then you will say "......aw, barnicles" hahahaha<br /><br />JAZZ
Barnacles are tough to remove. You can scrape them off but it still leaves the "adhesive line". I don't think I'd try anything harsher than pressure washing on this type of boat. After it dries out good, try some WD-40 to see if it will get up under the adhesive and release it. Let it soak.
Thanks for the tips. Anyone remember the "Odd Couple" episode where Oscar's dentist discovers the miracle barnacle glue? It released it's hold when exposed to moisture, after trying to get these damned things off of this dinghy I'm thinking they had a pretty good idea.
