Barnicle Removal?
boatride
Power-washed the bottom of my boat today. Removed most of the barnicle but left a dime size spot on the bottom of the boat. Power-washer will not take this off. Does anyone out there know how to remove these dime size things? Thanks for the help.
JB
Re: Barnicle Removal?
Plastic (NOT metal) scraper, followed by ZAP! or similar calcium dissolver.<br /><br />Good luck. :)
Fly Rod
You might want to try spraying Bleach. I use bleach on my trim tabs and it kills everything in about 15 minutes. Cheap stuff. I'm going to try a thin coat of vaseline on my trim tabs to keep the growth down.
AndyL
Disc Clean which is an acid brick cleaner works a treat, but is VERY powerful. Wear protective gear and goggles if using and wash off thoroughly after a few minutes.Test on small area and keep away from aluminium. Nasty stuff but barnacles and limescale hate it.
grumpoldmen
Can someone help me and tell me how to remove barnicles from the steel housing plate thats bolted on to the boat for the motor. I see the post forr the trim tabs will this work for the plate too.
Home Cookin'
youcan use a metal scraper on your metal parts.
Someone once said the only effective tool for removing barnacles is a checkbook.
