Base removal
jigngrub
Re: Base removal
Are you talking about changing your impeller/water pump?
Bifflefan
Re: Base removal
Look on you-tube and search impeller replacement. You will get a ton of vids. Some not so good, but others are spot on.
Chris1956
Re: Base removal
After you have removed the slinger, water pump cover, impeller and wearplate, use two large screwdrivers or flat bars to gently pry the base up and out of the gearcase.
meakers
Re: Thanks for all the help guys
Thanks this is what I thought I had to do but was not sure.
Moody Blue
Watch for and keep any shims you might find under the base. You'll need them when you reinstall the base.
