Boat: 1980's Sea Nymph Fishing Machine, 16' 6" V-hull
I had to replace the transom a few years back (there's a thread here about it with pic's) and cut the new transom down to a short shaft height to match the old transom. The problem I'm having is I never get on plane, it runs decent but never gets up on plane.
If I have the trim set to the second hole from the transom (current setting), the AV plate is almost even with the keel, maybe 1/4 inch high BUT the AV plate isn't parallel.
If I have the trim set to the third hole from the transom, the AV plate is about 1" above the keel and parallel to the keel. (haven't tried this setting yet)
From searching the web, perfectly inline with the keel is "standard" and slightly above the keel is for more speed for skiing, etc. I just fish, maybe pull a tube for my son but that hasn't happened yet anyway
I also purchased a 4-blade prop that is a breakaway prop (non-metallic) because I read that a 4-blade would get you up on plane faster. Problem is I never get on plane. So I ordered and have a new Quicksilver 3-blade prop (to specs for motor) that I am going to switch back to.
There was a time when I was able to get the boat on plane and it shot around the lake pretty good, but that was a long time ago. (carb rebuild and water pump replacement)
Is there such a thing as a short shaft 50 hp? Everything I search for ends up being 20" or 25". If that's the case. how would I go about altering the transom back to it's normal height? 20" Steel plates?
One more question: Is there a way to put the motor on a jackplate or just a mounting plate for this motor? There's only one hole for mounting and no adjustments for the clamp.
Thanks for any help here, it would be great to get this thing back on plane somehow.
