I have a 1989 Bass Tracker 1600tf fiberglass bass boat 16' with a 100hp Merc. It has a hydrofoil installed on the motor. I didn't like the look of it, so I took it off. The boat porpoised bad, even with the motor trimmed all the way down. With it installed, hole shot is great, and it rides nice, but as I trim it up to gain speed at wot, it starts to porpoise. Trim tabs will be in the way of my hold down straps when trailering, so I cannot use those. I the cavitation plate is mounted 2" above the bottom of the hull "v". I have moved the trolling motor batteries up front in the bow to help balance weight and that did not help.
Will a jack plate (5-6" set back) prevent porpoising?
Thanks
Thanks
