Bass Buggy Trailer Tire Size
papafrancisco
Does anyone by chance know the tire size for an 88' bass buggy trailer? I have tried to locate the leak, used green slime, submerged the inflated tire, soapy water, etc but it does not leak until there is a load on the tire. I figure I can fix this by installing an inner tube but the boat and trailer are at the lake and I am at a bit of distance hence the requested tire size. Thanks
Wingedwheel
Re: Bass Buggy Trailer Tire Size
Did you check the seal at the valve stem?
Ayuh,... All that, 'n you didn't notice it's Size,..??
Adding a tube will only cause More problems,... Replace the tire if you can't find the leak...
It's probably leaking through the sidewalls if they're cracked/ rotted...
