Bateau OB17 Build
Boater45
Here is my Bateau OB17 Build:
erikgreen
Re: Bateau OB17 Build
Looks good so far. Lots of questions pop to mind:
1) What kind of plywood did you use? How much so far? Did you cut it yourself or get a kit?
2) How long did it take to get to this point?
3) What are you planning on using for power?
4) How long do you think until you're done?
I started a C19 myself but then realized A) I didn't have time to finish it and B) if I did finish it I'd have a boat more or less like the one I have.. so I decided to spend time on that one when I got a chance.
Erik
Boater45
Continued:
Boater45
Erik
1. Meranti BS1088/the hull is 1/4'' and I'd have to look at the BOM for the amounts/I bought the plans from Bateau and cut the wood
2. Started at the end of the summer last year
3. Looking at a 75 Merc or a 90 Johnson
4. Looking to be done by the end of this year....hopefully this summer!!:confused:
Boater45
Fiberglassing:
Boater45
More fiberglass:
Boater45
Started Fairing the hull this weekend with QuickFair.....ran out....should have bought the 1.5gal vice the 1.5qt:
erikgreen
Yep, nice wood. It seems a shame to cover the stuff with paint later, it's so pretty with just epoxy on it :)
Boater45
Prepairing for the shoot thru hull transducer:
archbuilder
Great project, I may have to come out there and see it! Keep up the work, looks awesome!
Boater45
Why did you do this for a shoot thru hull transducer?:confused:
Thru hull transducers will not shoot through a wooden hull. So you have to cut a hole and fill it with an epoxy/filler where you wish to mount your transducer.
erikgreen
Any updates? I'm looking forward to more from this boat :)
Boater45
I ran into a stringer issue so my progress has been a little delayed while I put this fire out.:mad: Should have some progress pic's up by this weekend.;)
