Re: Batteries
A group 27 deep cycle is sufficient for your needs. The numbers to look for however, is the "Reserve Minutes" which is printed on the label. These numbers are something like this: Reserve Capacity: 145@20A load
This means the battery will operate a 20 amp load for 145 minutes or nearly 2-1/2 hours. Your 48# motor will draw about 42 amps at full speed but few people actually run them at that speed continuously. So while those numbers may seem like rather short run time, at slower settings that battery should last a full day or nearly so. The key is to find a battery that has the highest reserve minutes. Not all group 27 (or any other group) have the same reserve capacity.
