Battery booster
andy6.3
Re: Battery booster
I personally would not get one the battery in them is a 17AH battery and cannot provide much current they are SLA jelly cells. St the begining and end of the season do a drop test on the starter battery, if all good then keep if not get another bat.
Silvertip
Re: Battery booster
Jump start packs are like anything else, you get what you pay for. You don't need an air compressor on a boat so why not buy a better quality unit with a higher capacity -- but without the compressor. That said -- a jump start pack on a boat is a good idea, especially if you have only one battery. However, if you are one to run a questionable battery, then your money would be better spent on a new battery. If you have more than one battery, a set of jumper cables is all you need.
tashasdaddy
Re: Battery booster
any quality auto part store will load test your battery for free.
bruceb58
Re: Battery booster
You would be money ahead carrying a spare charged battery on board with jumper cables.
bijou22
Re: Battery booster
There is nothing wrong with my battery, its just in case,
Bonus
Re: Battery booster
I have that or a similar model it works fine. starts quite a few times before charging. I ussually use it in the boat in the summer and the truck in the fall winter. better than jumper cables.
Bob in CO
cjames
Re: Battery booster
isnt the "battery booster" just a battery in a box with some leads coming off?
