How do you know if your battery is fully charged? Volt Meter reads 12 Volts, Battery is a deep cycle. Also should the motor charging voltage be increasing as the rpms increase? Engine charges at around the 13 volt range, and was as high as 15 or 16 with very high idle.. 1966 Johnson 80 HP Super Sea-Horse<br /><br />My Volt Meter is a Digital Multi-Meter, Just wondering if I can somehow check the ampage,<br /><br />Also how long should I leave the battery charger on for? (Not a trickle charger)<br /><br />Thanks
