battery charger question
Dardy
Im new to boating and I am looking to purchase an onboard
Charger. My boat usually sits about a couple weeks between
runs. Its a 21' bowrider I would just like to know from people
With experience what kind of charger I should get also what amp of charger
Thanks
Silvertip
Re: battery charger question
First -- do you understand that an on-board charger needs to be plugged into AC power so having power available at the dock is required. The type of charger you need depends on how many batteries do you have? You need one output for each battery. If you only have one battery a 5 or 6 amp single output (single bank) charger is all you need. If you have a trolling motor or a deep cycle battery in addition to the starting battery you will need a two bank charger. There are lots of names to pick from. Guest and Pro-Mariner have been on my boats with more Guests than Pro-Mariners.
