vroom ZOOM
- Aug 15, 2017
- 427
Hello everyone.
I was thinking about building a battery combiner for my boat to have the engine charge my trolling motor batteries in between fishing spots. I typically sit for about 10 min at one spot and move to another one so I was thinking I could get some juice in on those runs. I am going to be using a chip to control the connection in between the batteries. I will use five relays, one to disconnect the two TM batteries from each other, and four to connect them in parallel to the cranking battery when the engine starts charging. My question - if I have two really low batteries, and the engine is started and the relays close, will there be a sudden rush of current, and will this sudden load on the engine charging system cook it? If yes, then I can ditch two of the relays and throw in some fat transistors and ramp in the connection, but this is less desirable since those transistors love to get hot and that means energy is being lost. I heard that all the battery combiners on the market right now are basically relays, so maybe i would be fine with the relays?
BTW reason for building one and not buying one for you curious people... I will have a few other systems tied in, and having this all connected to NMEA network is also a possibility.
