Re: Battery for a mercury 50
If you are just trying to start the engine, any battery with 350 CCA or higher will do the job. doesn't matter if its the one out of your car, a dual purpose (marine starting/deep cycle) or a deep cycle. However, if the battery you are looking for will be installed in the boat, then you want a Marine Starting battery or a Marine Dual Purpose (deep cycle/starting). A car battery will work and probably last a long time unless this is a small boat that will get banged around. Then, as pointed out, it will live a short life -- or maybe not. As for capacity, the smallest should be 350 CCA but batteries are cheap so install the largest capacity you have room for. You didn't mention the type of boat you have nor the type of accessories you will powering so that also determines the type of battery you should have. If you have a fish finder, lights, and perhaps a radio, a combo starting/deep cycle will be fine.
