BlueeyedRuss
- Aug 20, 2014
- 21
I have a 2011 Stingray with 4.3 lt Mercruiser ( carb). As I was preparing it for use this summer, I replaced the batteries that I had taken out for winter and kept on a charger/conditioner. It is a two battery one engine system. I replaced the batteries and had marked the cables in order to reconnect the same way it was last year. Last year when I winterized, everything worked fine. Now the gauges and part of the lights seem to be working fine, but much more does not. The radio and all its components are not coming on at all as if they have no power, at least two lights on the wake tower not working, and worse part of all, when I turn the key to start engine I here one loud click ( possibly the relay?) but nothing else. Engine does not turn over or anything just the click. It sounds weird but it seems that anything to the left of the batteries ( direction of one set of wires) works, ex guages, courtesy light, etc. but everything that runs to the right of the batteries does not work, ex radio, some lights, engine, etc. Batteries are good and fully charged. Im new to this and any help would be great. Low budget and trying to avoid costly service charges. Thanks Russell
