Battery / Ignition problem..
Dougan760
I have a Penta inboard outboard when i bought it (used) it started right up and every thing was fine. no problems,
Now when i hook the battery up and throw the switch on Battery 1 all the lights go on and the gauges light up,
But the key is not in the ignition... When i try to start it the engine does nothing does not turn over but in a few minutes both the positive and negative cables attached to the battery are hot to the touch.... what happened??.
Thank you for reading this.
alldodge
What VP motor?
Check the cables and see if they are connected reversed
