Ok From what i understand, linking one full battery to one discharged batter using a standard batter dial will cause the full battery to discharge a large amount of energy to the dead batter and damage it over time. Now i know an isolator will stop one battery from discharging another battery while the engine is off but does this principle apply when the engine is on or only when it is off and the the alternator isnt giving current to the center terminal? Ive also looked into the voltage sensing relay but im assuming when the engine is on the flow between the two batteries is uninterrupted. Oh and if i were to use the isolators would the separate banks still get their own charging leads from my 120v battery charger?
Thanks,
David
Thanks,
David
