Re: Battery Isolator Installation, Need Help
By the way, are you sure you don't have a three-bank isolator with a single alternator? If there is one main post on the isolator (along with the three output posts you describe), it would be intended for one alternator and three battery banks. This wouldn't be a disaster, as you would be charging the house batteries (2) off only one of the engines -- which should be fine. If you use the boat for fishing, I would pick the engine I use for trolling.<br /><br />No single battery should have multiple charging sources operating at the same time. I guess I'm a little curious about your setup. How many house batteries are you using?
