You may recall my recent frustration with my less than 1 yr old Deep Cycle trolling battery which at that time would quickly drop to 12.4 volts after charging and now has deteriorated further to 12.25 Volts a short while after Charging.
So I phone Minn Kota 1 800 tech support.
Me.....Hello Sir. I have a Charger Mod 105 P. My question is........Does this charger require unplugging or shutting off when the full charge green indicator light comes on??
Technician.......No .......Your Charger will automatically shut off when it senses full charge and goes into maintenance mode until it senses a voltage drop and then tops it up as needed. In other words it is a smart charger.
Me......So why do I get a 13.4 volt reading on my Multi meter (Green light on and no battery connected) when I connect it to the alligator clips on the Charger?
Technician........You have a defective charger and it has been over charging your battery if what you are telling me is the case. You should not even get a green light without a battery connected........the light should be red.
Me.........Thanks for your information. I now know why my recently purchased battery is on the way out if not gone:mad-new:.
