battery mystery
57lawney
a friend has been running 2 cannon 5 mag down riggers off his main deep cell starting motor,whitch is hooked to all the electronics in the boat. being worried over if running downrigers all day would leave him stranded, he bought a seperate marine battery deep cell, the downriggers have 3 position switches, up down&auto meaning if you hold the toggle up for about a second it will raise to a predeterminded stop. both units work perfect while hooked to the main battery, but when hooked to the other battery only the up & down work, not the auto, iwill add the second battery is just setting in the back of the boat on the floor. does anyone know what might be going wrong here? thanks for any help
Re: battery mystery
Ayuh,... If yer runnin' the downriggers all day, ain't he also trollin' all day,..??
With the motor Runnin',..??
How could the battery go Dead, when it's constantly being recharged,..?? The motor is Runnin'...
57lawney
Re: battery mystery
bondo, the downriggers are being run off a seperate battery, not connected to main battery
Re: battery mystery
Ayuh,... So connect 'em....
I donno what's up with the downrigger switches,... Maybe they won't work with low voltage...
My digitrolls work just Fine, but my battries are all tied together...
Fed
Re: battery mystery
I read the other day that some downriggers use the downrigger cable as a circuit to control the auto stop feature so if you don't have the stand alone battery negative connected to the main system it may not work.
