Battery Not Charging and fouling plugs
gop711
It's a 1992 Mercury - 60 HP.
Battery not charging (disconnected battery with motor running, checked leads coming from motor with volt meter and no power going to battery). Fouling spark plugs after running for an hour or so with no visible signs of plugs being corroded or burnt.
Any suggestions on where to start? Are the two problems releated?
As always thanks for your help.
Greg
Laddies
Banned
Re: Battery Not Charging and fouling plugs
When you disconnected the battery with the engine running you burned the rectifier/regulator out and there is a chance if the rectifier is shorted to ground that the stator is overheating causing a ign. problem
gop711
Thanks for getting back with me. At least I know where to start.
Greg
