My battery is good. What will keep it from charging while running the motor
H hl Petty Officer 1st Class Joined May 2, 2010 Messages 239 May 14, 2010 #1 My battery is good. What will keep it from charging while running the motor
saumon Lieutenant Joined Aug 2, 2004 Messages 1,452 May 15, 2010 #2 Re: battery not charging Bad rectifier/voltage regulator. What's your engine model/serial #?
H hl Petty Officer 1st Class Joined May 2, 2010 Messages 239 May 15, 2010 #3 Re: battery not charging I going to check it today. Thanks
H hl Petty Officer 1st Class Joined May 2, 2010 Messages 239 May 16, 2010 #4 Re: battery not charging It was the regulator. Thanks ,I learning slowly but surely
saumon Lieutenant Joined Aug 2, 2004 Messages 1,452 May 16, 2010 #5 Re: battery not charging Glad you found the problem and, BTW, nice to report back!
