BOWTECH.JUSTICE
- Aug 26, 2012
- 170
Have a 1992 4.3 mercruiser. Runs nice and would start right up. After motor gets warm I had to crank and crank and crank for it to start and most times battery would run down while doing so. Battery seemed as if it needed changed anyways, so I just put a new and bigger one with more cranking amps. So now when I need to keep cranking it will turn over a couple times and then seem to spin out. Also, a couple weeks back I noticed that there is a clicking sound as I'm turning it over. Does it have anything to do with the battery or is it just a funny coincidence that the starter could start going bad at the same time.
