Re: battery question
Like Oz said, the slower the discharge, the more amps a battery will cough up. The std spec for a/hr is based on a 5% rate of discharge, or 20-hrs of discharge (20hrs x 5% = 100% discharge). At 5% you get a reasonable amount of energy for the greatest length of time.<br /><br />There is a curve for other rates of discharge. This becomes important when using limited battery resource for high-amp demands, like trolling motors and house banks. Manf of quality bats, like your Trojan, publish the discharge curves for their bats.<br /><br />Aldo is correct, there are more specs for a battery than you can shake a stick at. They go on for pages and pages and pages. A couple of my personal favs are float life - how long before a bat dies if left on a float charge, and short circuit potential - how many amps would a bat cough up if it had theoretical unlimited capacity and you dropped a wrench across the posts.<br /><br />Nightvision you said the manf recommended a 105a/hr battery. We talk about a batterys capacity based on that 20-hr discharge rate. Common group-31, and group-27 bats are around 105a/hrs. Your Trojan (excellent battery, btw) is 85a/hrs
thats about right for a group-24 battery, and some gel group-27.<br /><br />Group numbers are a std for the physical fit size (H x W x D) of a battery and have no reference to a bats capacity, tho bigger obviously should imply more capacity. So all group-24 batteries will fit in the same space, all group-27 bats will fit in the same space, etc. Based on what the manf says, you want a minimum of a group-27 battery, a group-31 would be better if it will fit on your boat.<br /><br />The last pair of specs in your post refers to the batteries ability to cough up very high-amps at a couple diff temps. They are commonly referred to as CCA (cold cranking amps), what a bat can deliver for vehicle starting applications at 0-deg F, and MCA (marine cranking amps) for starting boats at or above 32-deg F. MCA is done at 32-deg F because you get a bigger amp punch when a bat is warmer than 0-deg, and since boats arent going anywhere in frozen water (think: ice below 32-deg F). The CCA spec is of little value for boats, except maybe to compare bats.<br /><br />Someone else can weigh in what the benefits of recharging your bat asap after trolling.
