Battery swap out difficulty for Southwind 2013 200SD
WChason
If anyone is familiar with 2013 200SD Southwind ?
My issue is there is not enough room to detach wiring and not enough room to remove battery.
Any instruction, advice, or experience would be very helpful. Thanks
Grub54891
Not familiar with your setup, but take some pullties, wrap around each set of wires on each terminal, so you don't get them mixed up. disconnect the terminals. I've seen some you have to take the battery put of standing on end. Or there may be a removable panel on the side to gain better access.
