christianL
- Aug 31, 2009
- 34
What seemed to be a simple fix has found a way to stump me, as with many "simple" boat problems.
I have a standard 2 battery setup, wired in parallel to a Perko OFF-1-BOTH-2 switch. All of a sudden when I flip to battery #1, I get no power to either the engine or boat accessories. I have plenty of test equipment and good electrical knowledge. Both batteries are brand new and have plenty of juice. I took the switch apart and checked for continuity between the posts the switch in it's individual positions, and all is well. there is also continuity between all grounds, cables, connections where there should be, etc. Am I missing something? Is there an engine ground I should be checking? Battery #2 position works like a charm, #1 does nothing.
Thanks for the help
Thanks for the help
