Battery Tester
key-z
Can anyone recommend a good battery tester? Need an easy read type for dummies.
Thanks , Key-z
rbh
Re: Battery Tester
Any multimeter will tell you how many volts are being charged into the battery and how much charge they have when the engines off, are you looking for a load tester?
JB
Re: Battery Tester
The simplest cheapest and most accurate tester of battery condition is a hydrometer, Key-z.
It might be a bit tough for dummies, but dummies wouldn't have enough sense to ask, so you shouldn't have any difficulty with one.
ThumbPkr
Re: Battery Tester
The hydrometer will be fine for batteries that allow access to their cells but many of todays batteries are sealed/gell etc. which precludes using any specific gravity device for testing.As mentioned,a load tester can be purchased at most auto parts stores and a digital multimeter can be obtained these days for very little money.Just measure the voltage at rest then again while charging.If there is no difference then the charging system is probably bad.Ron G
alumi numb
Re: Battery Tester
head to walmart and get a new charger, father in law just got one.
turn it on and it does an analysis then lets you know if the bat is good or not.
roscoe
Re: Battery Tester
For what type of battery?
auto starting battery?
d-cell?
Re: Battery Tester
Ayuh,.... This is what I use,...
DaleT
Re: Battery Tester
I'm with the "what type of battery" crowd. Assuming you are speaking of auto type batteries any of the above suggestions will work. If you are speaking of Li ion, NiCad, alkaline, or smaller lead acid batteries more information is needed. Also, what type of testing do you want. Not all batteries can be tested the same way. For example, my occupation uses a large number of rechargeable batteries (Li Ion, NiCad, and Lead Acid) we spent about $2000 on a battery tester and then many hours setting up the tests (honestly we should have opted for a better, more expensive model as this one doesn't work 100%). For home use this would obviously be overkill but we needed to know many factors to properly gauge when to replace batteries.
