Re: Battery upgrade
I'm cheap. For a second battery I bought a lawn tractor battery at Wal Mart. I use it for electronics, a water pump, and inflators. I used the tractor battery because it was only $25.00 and is 1/2 the size of a standard battery. Most electronics draw very little current so I didn't need a huge battery. The batteries are wired in Parallel, that is + to +, - to -. I left the motor start and charge wire tied to the primary battery. I moved everything else to the second battery. THEN, I wired in a standard home light switch on the + to + wire. Switch on, both batteries will charge when the engine is running. Switch off, everything is isolated to the 'little' battery. Just as a test, I left the switch "OFF" for a couple of days, running the GPS, XM radio, boat radio, and VHF radio. After 3 days everything was still working, the little battery hasn't discharged.
Total cost: Battery, $25.00. Light switch $3.00. Outlet box 1.50 Cover plate $0.30. So, for less than 30 bucks I have duel batteries. IF you are going to use a trolling motor, or use the second battery as a back-up starting battery, THIS CHEAPO METHOD WILL NOT WORK, the light switch can not handle the current draw of the starter.
Good Luck
