Re: Battery Wireing
Tbot you can do what you asked but it is not recommended. The reason is a pair of 12v batteries wired in series to provide 24vs benefits from being the same size, make, and model to create an even load on all 12 cells.<br /><br />You are correct about series and parallel. Batteries in series increase voltage, batteries in parallel increase amp.<br /><br />Think of a 12v battery not as a box that can store 12vs, but rather as a collection of six boxes, each storing 2vs. Those six boxes are wired in series to provide 12vs. When you wire a second 12v battery in series, you now have twelve 2v boxes in series.<br /><br />Your battery system is only as good as its weakest 2v cell. With twelve 2v cells in series, placing a 12v load somewhere in the mix puts an uneven wear-n-tear on six of those cells. In this situation you can never realize the full useful potential of all twelve 2v cells.<br /><br />Personally, I would not worry about a minor 12v load on a 24v battery system. I would not consider doing so with lights that pull any significant amps or are lit for a significant amount of time.<br /><br />When you do need a bunch of 12v amps, either toss a third, independent battery into the mix (it has its own issues
like charging and stuff like that) or use something called a step-down converter. It is a box with 24v input and 12v output. They are made just for the application you mention. The disadvantage of converters is 1) price, and 2) inefficiency. They typically output 90% of the energy input. So if you need 10amps of 12v energy for your application, the converter will pull the equivalent of 11amps worth of energy from the 24v system (actually 5.5amps at 24v).<br /><br />I hope that helps. If you would like to post back here with your specific application there are lots of knowledgeable, experienced people here that can offer suggestions on how to properly wire your application.
