BAYLINER 120 HP L DRIVE STARTING PROBLEM
marcusmg
Had run this boat yesterday, all was well for several hours. Upon <br />restarting boat, it sputtered once then died. After cranking twice it<br />seemed like the battery was dead. Today I had the batterey checked and it<br />checked out fine. Put battery back into boat and cranked several times then<br />again seems like it is low on power??? Again battery checked out alright.<br />Could it be a starter issue? but why did it sputter then die, after running<br />it for several hours?<br /><br />any suggestions would be appreciated<br /><br />thanks<br /><br />model # 120LD90C
Hooty
Re: BAYLINER 120 HP L DRIVE STARTING PROBLEM
I wouldn't assume the problems are related. Connect your volt meter to the pos. post on the starter and be sure it's getting a full 12 volts when starting. If not, start looking for loose or corroded connections or maybe a sick starter solenoid. <br /><br />c/6<br /><br />Hooty
