Re: Bayliner 175 Audible Alarm sounds (Accersory not working, but engine works fine)?
First......Things first, :welcome: aboard, hope you enjoy your stay.
So if I get this right, the alarm(I/O engine?) is going off with a fine running engine but ONLY when you have turned on essentially every accessory? And when you have them all switched on and the alarm is sounding, those accessories you have turned on, failed to come on/work?
If I understood right? I'd guess there is a low voltage monitor(hmm, i better code that in my monitor, beer goggles happen, ty) in the system and I suspect ya might just have a alternator/connection issue.
Questions...
1) Does just one or two accessories work up until about the last switch is turned on and then they all just shut off in a instant and the alarm sounds? or
2) Not even one accessory works by itself but, it still takes about all switches on to get the alarm to sound?
3) Do you have a voltage meter(or on-board voltage gauge) you can view as a tool and can check? If so, with engine running, watch that thing as you progress down the switch line, if the meter is bumping down in voltage levels further and further w each switch in-turn(from say 12/13 volts to say alarm on and/or 10'ish volts), ya probably just aren't charging.
