Captain Coromandel
- Jul 9, 2009
- 2
We hit a rock with our Bayliner 175 BR and the local repair shop replaced the lower half of the drive. They had a shorter ratio unit in stock so it now has about 1.8 instead of the original 2.0. To compensate this they used a Mercury Enertia propeller 48-898994 which to my understanding is 14 1/2 x 17. I read somewhere that the original black max is 14 1/4 x 21.
The problem is now that after 30 mph the boat starts to pull to the left. Top speed is 47 mph @ 4250 rpm (previously 43 @ 4800) where you really have to hang on the steering wheel to keep it straight. The adjusting fin is turned to the max on left side.
Is this normal behaviour or is there something else wrong with the boat?
Repair guys say they'll fix it with smaller prop but I'm not fully convinced with them anymore. Will the boat now always be pulling to left if I want to keep the lower rpms (which i like since we are purely cruising) due to the lower gear ratio which requires even bigger prop than original would have?
If the repair guys are right and this can be sorted with prop selection, which parameters should be adjusted to get it right? Or do I need the original gears in the drive to get this right?
Or what, am I missing something totally?
