Bayliner 17ft Capri Cuddy 85hp o\b capacity plate
riptorn
Of all the boats that I have owned, this is the first boat that doesn't have a Government plate on it with the weight load restriction. There is a faded silver tag beside the 85 hp Force (passenger side) with nothing on it. Is Bayliner that cheap to put a proper tag on their boat or are we responsible for this.
This is new to me for Bayliner. Other boats I have owned have always had a capacity plate on them. Hope some can fill me in
MarkSee
Re: Bayliner 17ft Capri Cuddy 85hp o\b capacity plate
Back in 83 my 16ft Bayliner 1600 with Force engine had a capacity plat in the cockpit and that similar brand new 2012 model I saw a few weeks ago at the boat show had a sticker. What you have not provided is any information on the year of boat as I would think a search on the Internet or a call to your local Bayliner dealer would find your answer.
Mark
Mark
Ayuh,... Of All the boats I've had, 'n ALL the times I've been pulled over/ talked to by the Powers that be,...
I've Never, Ever once been asked about that tag...
A couple years ago, I went through the Whole Coast Guard Inspection,.....
They didn't care, at All 'bout that tag...
Just the fire extinguishers, flares, etc...
I even got the Golden Slip. aka; flash it, 'n they don't bother Reinspectin' ya...
riptorn
Mark
I searched the net all over an could not find a photo of the tag of my 1988 Bayliner Capri Cuddy 85 hp, but I did find the specs here at iboats
5 PERSONS OR 625 LBS
1200 LBS PERSONS, MOTORS, GEAR
85 H.P. MOTOR
NYBo
They used a vinyl sticker that was attached to the the vinyl on the center of the port side console. Although I have the bowrider version of your boat, my capacities are the same as you listed. I can try to send you a scan of my sticker if you like. It's currently stuck to the front cover of my owner's manual, courtesy of the previous owner.:facepalm:
riptorn
I would appreciate that very much Captian. My tag is fade right out
riptorn
BlkY2k
My 1990 1700 capri is only rated for 50hp and it could really use the extra 35hp. :mad:
NYBo
The size of the sticker is 2"x4".
riptorn
Thanks NYBo. I will take another look in the boat for it now that I know what it looks like.
