Hey guys - had the boat out for the first time in two years today and noticed when I got her home that the motor going down is making a strange noise. I didn't notice it when I was out, but that doesn't mean it wasn't there, just that I might not have noticed. It trims both up and down fine (or at least it appears to), but it sounds normal going up and sounds strange coming down. Almost as if it has air in it or a motor issue. I did notice the fluid might be a little low, but it wasn't super low - there was fluid in the reservoir. Video link below. Would love to know what you guys think it might be.
https://www.youtube.com/watch?feature=player_detailpage&v=PnL4Klc4sL8
Also, I changed out the impeller last week and noticed today that the temp fluctuated between about 175 and a couple of clicks right of that (between 175 and the next line - which I believe is 200). It ran fine and never got higher than 187 (again - the middle of the two lines 175/200). Is that normal and if not, what should I check. Motor ran fine and strong and had her up to about 43 knots. Should I change the thermostat? One other item of note is that water temp was about 83-85 today. Pic of where it was below:
