Need some suggestions. 1987 18' Bayliner with 3.0, OMC outdrive. Needless to say its a little slow out of the water, but it will get the job done. We usually have 4-5 adults in and somtimes pulling a tube. It has a 15P stock prop on it right now, but it will overrev by 2-300 rpm at WOT, even with 4-5 adults after struggling out of the water. I know a 17P prop would help with the overrev but I dont want to hurt the bottom end any, in fact it could be better. We rarely ever run at WOT so top speed isnt really an issue, as much as getting out of the water and staying our of the water at part throttle is.
My question is.....
Would a 15P 4 blade prop help get it up out of the water easier?
Would there be any downsides to a 4 blade prop.
Would a vented 17 be better yet?
Any suggestions on props? I am going to stay with aluminum, are the solas props any good?
thanks in advance..
My question is.....
thanks in advance..
