Bayliner Capri 1986 Engine problem
Tamster0420
1986 Bayliner with Volvo v6 eingine. just change Double universal joint and boot just replaced but now the engine knocks. motor still runs but making that sound. What do you guys think it is?
Gary H NC
Re: Bayliner Capri 1986 Engine problem
If the noise just started after the Ujoints were replaced then i would pull the drive back off.Start it up and see if the noise is gone with the drive removed.
If its gone recheck that the ujoints are in correctly.Also make sure all is straight using an alignment tool.
jmills224
Did you replace the gimbal bearing and what was the reason for the U-joint and bellow replacement? The reason I ask is if you got water in the bellow and it wrecked the u-joints, your gimbal bearing probably needs replaced as well.
Dakota47
Rod bearing going south??
Ayuh,..........
That'll point you in the Right direction to finding your Knockin'.........
