Bayliner key question
Fun Times
What year is the boat? Inboard or outboard?
In some cases if you look at the front of the key switch there may be a small letter scribed into the switch, if so you can try calling around to some of the boat dealers to see if they have any keys with that letter on the key itself.
Below is an example as you can see the M at the end of the key number of the Perko switch,
http://www.ebay.com.au/itm/Marine-B...8dc87a9&pid=100011&rk=1&rkt=7&sd=171186344603
If it's an Merc/force outboard then try this as well, Lost Ignition Key
alldodge
Hey ... i have a bayliner i am restoring. How do i get a key for the ignition?
Back Hey
Look at the number of the cylinder, there are only about a half dozen keys and the dealer has plenty of them. Either that or replace the key switch
