Bayliner Throttle won't go in gear
gobo8391
:confused:Hello,
I have a 1995 Bayliner 2050 with a mercruser 4.3. Alpha 1.
It won't go into gear... Any help where to look first, 2nd, etc...
Thanks a bunch!
Bo
Reel Poor
Re: Bayliner Throttle won't go in gear
Are you saying the control lever won't move, or it moves, but no response from the drive?
Haut Medoc
What he said^^^^^^......
You're gonna have to be a bit more descriptive of your problem......:)
Bt Doctur
Outdrive missing / stolen
really need as much information as you can supply.
gobo8391
OK!
I looked at it today and... When you try to move the throttle lever, it does not want to move much. It will not even move the cable at the throttle linkage. It will not go into reverse at all. When you disengage the throttle, it will move freely forward. Could it be a bent cable? Or something up in the throttle lever itself?
I hope this will help you and me. Bo
Don S
Disconnect that cable from the shift mechanism on the engine (The one with the spring thingy) and give it a try. If it works, have a helper try to hold the cable end from moving. If he can, replace the cable.
ccmarsh
The one with the springy thingy aye Don. Don't get to technical:D
