joemamma_222
- Jun 23, 2003
- 201
Merry Christmas to those who Are into it and Merry Christmas to those who dont ! o
... my boat is all stored up and it'll be warm tommorow
. this is a new boat to me but I believe it's mid 80's with what looks like a bayliner engine controlls (blue and silver b's ??). the last time we went out the N moved forward on the controll. Normally a Red button is depressed and the controll can then be moved F or R the N lock no longer works and the acutual N position is a bit forward now like instead of N being 12 o'clock high N is now at 10:30. The first few times out this was a NON issue. This is the type of controll that will "choke" the engine by pulling the whole thing away from the mount and it disengages the Shifting Cable. (so you can pump the throttle only) if that gives you more of an idea of what I have. The boat shifts smoothly and I can achieve Wide Open Throttle. When looking at the lower unit (with the cover off) the shifter arm moves in it's 3 positions. So everything shifts smoothly and in all positions where else can this thing "slip" ? Thanks alot I gotta get to bed Santa's commin and I know he aint bringin one of these ! I'll look for a pic if the controll and post it.... THANKS !~
Joe In Ohio....
Joe In Ohio....
