Hi,
I am ready to reassemble the drive shaft bearing of the lower unit.
I see in the parts list a bearing sleeve PN 23-85092.
I did not get one of these out when I ground out the bearing.
Am I missing something?
Thanks,
J
I thin that they are refering to a sleve that is in the front part of the one gear that is in farthest in the gear case housing. From the way the diagrams look that gear has a brass bushing sleve that the prop shaft will spin on when the motor is in reverse gear. JMO
Oldman570
