Hey all. Been awhile since being on here. Not much has changed since last here other than i got home with boat. (You could look at my last post to read it if you want)Its a 1988 citation cuddy cabin with a 3.7 mercruiser. It was listed as running in item description but of course i get home and try to start it up and nothing, not even a sound from the starter. The ignition fuse for whatever reason (short in wire somewhere?) Got extremely hot. I was a little discouraged and haven't done a thing with it since other than look at it and imagine what could be.
Anyways where should i start?
Trailer needs a little tlc nothing major
floor is a lil soft in back around engine
engine doesn't turn over but i can turn it by hand so not locked up.
all lights,marine radio and stereo work (need new speakers for it however)
Was thinking i should set boat off and get trailer fixed up first. Then gutting the interior/floor (replacing floor and interior after engine repair). Then engine work.
Sound like the order i should go?
thanks in advance
thanks in advance
