beep....beeep....beep...when motor is in the water
tsgarbi
I have a mercury 150 efi outboard. runs well. fixed the problem with the reverse gear thanks to this forum. now when the engine is in the water and running, it keeps beepingbeepbeeepbeeep........ when I tilt the engine up, the beeping stops. oil is full both thanks, presure is ok, caps are tight... what could it be..
help
thank you
north40
Re: beep....beeep....beep...when motor is in the water
Sounds like an oil warning sensor gone bad.
tsgarbi
My optimax used to do that until it flushed(peeing) Is yours flushing when the tilt is down or just up.
Yes it keeps beeping all the time as long as the motor is down.
when I tilt it up and out of the water, it stops beeping
thank you
tsgarbi
Is the sensor you are talking about in the oil tank or in the reservoir on the motor itself?
Thank you
Texasmark
I'll agree on the oil sensor and I'd bet the oil tank is in the engine.
Mark
