beeping alarm
bauc
i need a model # for my 60hp mercury pro series. ser.# 0G107026. i need it to find some info about the alarm going of. :confused:
ob
Re: beeping alarm
Your serial number indicates that the engine is a 1994 model.Not familiar with Merc alarms.Someone else will help shortly.
sharkcat
Re: beeping alarm
If the alarm is continuous its overheating.Causes bad water pump stuck thermostat/poppet valve or if on muffs turn the tap on harder.If the alarm is intermittent its low oil level check oil level in tank if full & alarm is still going off disconnect wire fom the tank if the alarm stops the problem is the sender in the tank ...buy a new tank.
bauc
Re: beeping alarm
thanks alot for the answers from OB and sharkcat. it gives me something to look at. am very new at this boat problem stuff. thanks again
