Kauaiboy206
- Mar 9, 2017
- 133
Is the old one even worth keeping for a back up?
Welcome Aboard,... Nope, not really, a buck or 2 in scrap,...
Didn't get the chance to check it out yet, but I'll try that today atleast I can get the bell housing off if poasible from the alpha 1 & hopefully ready for the transplant on the mc-1 horseshoe gimbal collar.I'm not sure on an MC1 but a half inch Allen wrench works to remove the hinge pins on an alpha 1.
Is it possible to perform a compression test without the outdrive installed? Can I simply run a garden hose into the port hole?
Ayuh,... Yer not gonna start it, but just roll it over on the starter,...
With the drive off, the impeller ain't turnin',...
So,... No reason to feed water to it, at All,....
As for fixin' the corroded junk, you'll have more into the repair, than you can buy another used unit for,...
The MC1 is held in place by solid round stock retained by SS nails. TheAlpha is held in place by threaded hinge pins. not a direct replacement
Got the reading, 1 & 2 got 120, #3 got 119 #4 got 119-118ish. Are they good reading? Is a follow up test necessary?
Ohh man that means I'd have to install the entire alpha 1 transom & gimbal assembly? The donor did not come with the opposite transom plate, will my mc-1 work? Or do I need to obtain the alpha 1 plate?
Why not just buy a good used MC-1 bellhousing and hit the water, if that's all that's wrong with the current set up??? I've bought several for $50-75 on eBay. It would cost you way more time and money to fit your Alpha donor parts on there. Once you start talking about swapping the transom plates, the engine has to come out, and then the list of "while you're in there" stuff just keeps growing. Not to mention parts you need to buy to complete the swap. Been there, done it. I would have rather been out on the lake.
Look at his pictures. The MC-1 is the later (post about 1976) with the senders mounted on the gimbal ring. DIRECT swap for the Alpha One.... Infact, what I would have done is pull the complete MC-1 transom assembly off and put the Alpha One unit on. The MC-1 (later model) inner transom plate should bolt straight up to the Alpha One outer... Everything else remains the same....
Chris.....
Question is, will those xd trim cyLinder work?
Yes,....
Yes,....
