I need to replace my driveshaft bellow on my drive and was reading that you are suppose to use bellow glue when installing the bellow. After further reading I found that some people only use it as a precaution to make sure that the bellow doesn't come off when reinstalling the drive. While others say that it will be okay without the glue as long as you make sure it doesn't get bumped off when installing and make sure that the clamps are on tight.
Do I need to get the glue for the bellow or will I be okay if I just make sure that it is clamped on tight and there is no gaps?
