Bellows kit??
BellevilleMXZ
Have an 05 Rinker 270 with duo prop drive, I want to change both bellows, shifter cable boot, etc. this winter, does Volvo make a kit, or do you have to buy everything separate? And whats there TO change? 2 bellows, shifter boot, gimbal bearing, ......seals between drive when take it off? And of course ill check alignment and ujoints.
bruceb58
There is no shifter boot.
You buy the bellows separately.
The only seal you replace is the oblong seal at the water inlet between the drive and the pivot housing.
Don't bother with the exhaust unless it is ripped.
jerryjerry05
Buy Volvo.
The aftermarkets can be stiffer and sometimes don't fit as well.
BellevilleMXZ
There must be some kind of seal where cable comes though?
