Re: Bellows life span???????
I give the Mercruiser, OMC, and Volvo SX/DP-S style drives 5 years on the bellows, only 2 years on the Volvo 290 style (270 thru DP-E drives).<br />The Merc bellows are pretty tough. But there are a lot of people that try to reuse that big rubber ring and that is a NO-NO. That is a one time use item. If it gets cut or out of place, you get water in the bellows just like having a hole in the bellows.<br />IF you are sure the water is coming in from the bottom of the transom shield, it could be the transom shield seal, or the seal ring between the exhaust Y and the transom sheild. I' seen a lot of the ears that the bolts go through on the bottom of the exhaust Y broken off, and that will cause a leak.<br />IF the leak is up higher, it could be the shift cable bellows, or the ujoint bellows (or seal ring)<br />Pull the drive and check the ujoint bellows for water. That's a quick and easy check.
