craze1cars
- Dec 26, 2004
- 1,822
You guys are so helpful...I'd like to present another question. I'm starting to struggle through bellows replacement on my Alpha 1 Gen II. Doing all 3 bellows and the water inlet tube. Again relying on my rather poor (in my opinion) Clymers manual, they say to remove the bellhousing you need a special tool and may need to apply heat to get the pivot pins out. This scared me, so I am working through replacing them all with the bellhousing still in place. Obviously I am struggling with clearance and room to get wrenches & screwdrivers in there, but I'm making slow painful progress...would be much easier if I could just take the bellhousing off. Any tips? Do I need the special tool or can I improvise? Do these pins generally come out easy enough? What kind of heat needs to be applied? <br /><br />Question # 2...The Ujoint bellows has an obvious hose clamp on the transom side, but on the bellhousing side I see no hose clamp (again, contrary to what shows in my Clymers manual), it's maybe a collar pressed into the INSIDE of the hole? I don't want to break anything. Does this collar just friction fit so it gets hammered inward from the outside? Or is there some other way to get this off? And how will i get the replacement set in there? Thanx. Haven't received the new one yet to compare, waiting for my "kit" to arrive from Ebay. Thanks again...I'm an auto mechanic and generally quite capable at fixing anything, so this boat crap seemed like it should be pretty easy, especially with a manual to help guide me, but I must be making it harder than it is.
