Hey guys, I have a 19' bowrider with the Mercruiser 4.3 Alpha 1 Gen 2.
Need to know if there is a correct order of install i should follow for installing all the bellows, and if I am supposed to install them on the gimbal housing first or the bell housing first?
More information: I have a complete bellows kit, (gimbal, exhaust, shift cable, all clamps, etc) also has the water pickup tube and gimbal bearing. Also have two new u joints and an impeller kit. The outdrive is off, the lower shift cable is out, the bellhousing is off, the gimbal bearing is out, and also the two u joints are out. I do have the bellows spreader tool and also a Seloc manual but it is fairly vague, so looking to you guys for help!
