belt change Mercruiser 120
captainnate
I know there are no dumb questions, just dumb people, right? I think I might be one of those. In changing the alternator belt on my 72 merc 120 (sn 3331071) I moved the top pulley slightly; does this matter? Was I suppose to mark it or something. Somehow I thought maybe the valves might not be aligned because I moved the pulley slighty. On the other hand it doesn't seem right, because that belt must be able to slip. Thanks.
Alumarine
Re: belt change Mercruiser 120
Nothing to worry about. That belt just drives the water pump and alternator.
captainnate
Thank you for the response, marc c. I obviously have plenty to learn.
captainnate
how do you know if the tension is correct?
achris
More fish than mountain goat
On the longest run between pulleys, just push the belt with about 10lb of pressure, belt should move about 1/2"
Chris.....
